1996 Dodge Ram engine does not run
225,000 MILES • V8 • 2WD • MANUAL
MBROCK42
Truck stoped running while I was driving. I think that it may have seased. Is there any way I can tell before I take it to the repair shop.
Nov 14, 2009 at 12:28 PM
JDL
  • 16,098 POSTS
Welcome to the forum. Remove the plugs and accessory belt/s, see if you can turn the crank by hand? All the fluids ok?
Oct 4, 2018 at 3:34 AM
MBROCK42
Pulled plugs and belts, would not turn. The dip stick is stuck so cannt check hower it does have some oil I looosend the drain just to see if there was any. Whats the next step. Pull the engine?
JDL
  • 16,098 POSTS
Did you notice anything before it siezed? temp lite-- oil lite-- anything? You can pull oil pan and heads, see if you see anything? That's up to you.
MBROCK42
No. everything seemed normal. Thank you for the help. I'm going to pull the heads next. I'll keep you posted. Thank you for the time
JDL
  • 16,098 POSTS
Just a thought, if you think the piston/s is siezed? With plugs removed, pour a little oil in each spark plug hole, let it set for a while, see if they come loose? Although the cylinders may still be damaged?
