1996 Dodge Ram Engine, after warming up, begins to sound li
PIJA
  • 1996 DODGE RAM
Engine Performance problem
1996 Dodge Ram 6 cyl Two Wheel Drive Automatic
Garages changed fuel lines & filters, fuel pump, changed plugs & wires, cleaned fuel tank, and changed injectors but problem still there. Can a dirty pcv valve cause this problem?
Sunday, February 24th, 2008 AT 9:20 AM
BLACKOP555
  • 10,371 POSTS
What seams to be your problem, your title seems a bit cut off!
Saturday, March 15th, 2008 AT 6:05 PM
PIJA
Sorry about that. The engine begins to sound like a diesel engine after it warms up (slight shaking). Can a dirty pcv valve cause this. Someone said it is sensors, but engine test lights test okay. We changed fuel pump, injectors, plugs, fuel lines, cleaned fuel tank, etc, did not fix. Forgot to check gap on plugs; could this cause it?
Monday, March 17th, 2008 AT 12:06 AM
