1996 Dodge Ram Do I need to replace my compressor
11,700 MILES • V12 • 4WD • AUTOMATIC
GUGIE
I've had a condenser that has had a small hole in it for the last three month. I'm getting ready to replace the condenser and the accumulator and receiver drier. I was told that since the compressor was still spinning whenever I had the defrosters on that I'll also need to replace the compressor. Is this true? How can I tell if the compressor needs to be replaced?
Sep 4, 2009 at 3:53 AM
CARADIODOC
  • 34,415 POSTS
Do I understand that since the compressor was obviously still working, you need to replace it? Sure, that makes sense.
It's true the compressor will run in defrost mode to remove moisture from the air before blowing it onto the cold windshield, but there's also a low-pressure cutout switch in the system. When enough refrigerant leaks out to where the low side pressure drops too much, the low pressure cutout switch stops the compressor from turning on. This is done to prevent it from sucking the low side into a vacuum which could draw in moisture through the leak.
There may be other reasons someone recommended replacing the compressor, but not simply because there's a leak. It IS smart to replace the receiver / drier whenever the system is opened for service.
caradiodoc
Sep 6, 2009 at 8:10 PM
