1996 Dodge Ram cylender heads
1996 DODGE RAM
148,000 MILES • V8 • 2WD • AUTOMATIC
SAFIARIZONA
i was wondering what the labor on replacing both heads on my van without parts would be..
Mar 30, 2009 at 1:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Approx. $500 to remove and replace both cylinder heads & gaskets not including parts.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_392.jpg
Thanks for using 2CarPros.com!
Mar 30, 2009 at 3:12 PM
SAFIARIZONA
so if im being charge 1000 im being charged to much. not for just a gasket change but a head replacement
Mar 30, 2009 at 4:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is the $1,000 for labor only?? If so then I would say that is too much..in order to replace the head gasket then you have to dissamble the engine down to the heads so there is nothing left to do at that point then to remove the heads..so the estimate I posted above may be off by about $50 to $100 but for removing and installing both cylinder heads on your vehicle it should only cost around $500 - $600 .. Please remember this is LABOR cost only.
Mar 30, 2009 at 6:21 PM
