brake and abs warning light
121,000 MILES • V8 • 2WD • AUTOMATIC
NASHDADDY75
I have a brake and abs warning light that stays on after startup. The guy I bought the truck from says he took it to a Dodge dealer to have a diag. done and they could not figure out. I have done some reading and am finding out that it might be the VSS. Can you shed any light on what I can do to fix this problem?
Thanks
Nash
May 4, 2010 at 3:49 AM
  • 110,244 POSTS
I would be more likely to believe that it would be a ABS sensor on one of the wheels. The VSS will likely cause an odd transmission shift.
Mar 1, 2021 at 4:41 AM
CALITAZ81
The VSS on the rear diff is your ABS sensor. My truck is doing the same thing, leading me to believe the combination valve or RAWL valve on the master cylinder is bad.
  • 55,530 POSTS
Easy to find out watch this video and it will tell you whats wrong.
https://youtu.be/rTtAnsOlZU4
Once you know the code, all easy. Please run down this guide and report back.
