1996 Dodge Ram back up lights
1996 DODGE RAM
MIZZ93
Electrical problem
1996 Dodge Ram V8 Automatic 98000 miles
both backup lights are not on. Where do I find the fuse box on this vehicle so I can check the fuses
Apr 4, 2010 at 12:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the fuse block is located on the extreme left side of instrument panel, open driver's door fully to access it. check fuse #15 (10 amp). if OK suspect faulty park/neutral position switch, located on left side of transmission.
Apr 4, 2010 at 12:47 PM
