1996 Dodge Ram 4 wheel drive problem
104,598 MILES • V8 • 4WD • AUTOMATIC
LUKE1975
when I have it in 4 wheel drive it makes a noise when I am slowing down. the noise comes from the front right side. what could it be. Thanks for your help.
Dec 18, 2008 at 2:42 PM
  • 110,251 POSTS
Hi:
Can you describe the noise?
Dec 19, 2008 at 2:49 AM
LUKE1975
[quote="luke1975"]Noises problem
1996 Dodge Ram V8 Four Wheel Drive Automatic 104598 miles
The noise is a squeak and has a little shake to it also.
is it maybe a bearing?
Dec 22, 2008 at 2:07 PM
  • 110,251 POSTS
Hi:
Two things I would check, the front axle joints and the front brakes. Let me know if this helps.
Dec 22, 2008 at 10:34 PM
MACPLEE
I have the exact same problem with my 2001 Ram. The the front end squeak high and low noises when in 4WD and only when the truck is moving. No noises in 2WD or when the truck is not moving.
Feb 15, 2009 at 11:33 PM
