1996 Dodge Ram 1996 Dodge Ram 1500 4x4 Engine Noise :-(
186,000 MILES • V8 • 4WD • AUTOMATIC
RANCH98642
1996 dodge ram 1500 4x4 pick up while driving on the road all of a sudden starting making a very loud noise (sounds kind of like a fan hitting something, but isnt) from inside the engine, what can it be? I know nothing about mech. stuff.
Sep 17, 2009 at 9:39 AM
ANJR
  • 32 POSTS
[quote:03dff8df1b="Ranch98642"]Engine Mechanical problem
1996 Dodge Ram V8 Four Wheel Drive Automatic 186000 miles
1996 dodge ram 1500 4x4 pick up while driving on the road all of a sudden starting making a very loud noise (sounds kind of like a fan hitting something, but isnt) from inside the engine, what can it be? I know nothing about mech. stuff.[/quote:03dff8df1b]
Can't be more specific without more info, but the 2 most common problems in an engine with that many miles are lifters & bearings.
The lifters require a certain amount of oil-pressure to operate properly and if the pressure drops for any reason, they'll "collapse" & "rattle like a bucket of bolts". Normally an oil/filter change, using a high quality, heavy grade oil, @ least 20W50, will take care of that. Personally I use a straight-weight 50 in an engine with that many miles.
If it's not lifters, then it could be either a "spun" bearing or the "death rattle". The 1st caused by lack of oil between a bearing & a moving part like the crankshaft. The part can "sieze" the bearing & spin it right around - no fix for that other than rebuilding the engine.
The 2nd is usually heard when the oil level is too low and/or too thin of an oil is used. As the miles rack up, the clearance between moving parts & the bearings that support them increases & without a good, thick coating of oil to be the "cushion", the part rattles around inside the bearing. Heavier opil can keep the engine going for a while longer, but sooner or later it will have to be rebuilt.
Sep 18, 2009 at 6:50 AM
