1996 Dodge Ram
318GIRL
  • 1996 DODGE RAM
  • V8
  • 4WD
  • 10,600 MILES
Driving down the road the oil pressure drops off. So we put on a mechanical oil pressure gauge. When it is idling it seems fine but when you go to 2000 rpms it drops off again and then you let off the gas it goes back normal. There is a ticking under the driver side vavle cover. We just put new head gaskets on so we thought when we were cleaning the surfaces for the new gasket some dropped down and clogged the oil pump? Do you know whats wrong?
Sunday, May 4th, 2008 AT 3:26 PM
MASTERTECHTIM
  • 4,750 POSTS
Yes I know what wrong. Remove the oil pan. Do not run the vehicle anymore. The oil pump pick up screen is clogged and will be cheap to fix if you do it now. If you keep running engine you will ruin it.
Sunday, May 4th, 2008 AT 3:39 PM
