2001 Dodge Ram OIL PRESSURE GAUGE
KEN M
  • 2001 DODGE RAM
  • 6 CYL
  • 77,000 MILES
The needle on the oil gauge drops to 0 and the check gauge light comes on and bell sounds, then when I press on the gas the pressure goes up and light goes out. Let off the gas and happens again, so far I had the pressure switch replaced twice and I also had a new high performance oil pump put in, at idle I have now 10 lbs of pressure at idle and it is still happening. Driving me crazy. Hoping you might had a suggestion, my mechanics don't seem to know whats wrong.
thanks, Ken Marquis
Sunday, April 20th, 2008 AT 1:34 PM
  • 31,937 POSTS
Hi there,
Check the engine oil pressure with a master gauge. This will give you a true indication as to the oil pressure. If the pressure is ok then the problem will be in the electrics of the sender and gauge.
Mark (mhpautos)
Monday, April 21st, 2008 AT 5:59 AM
