1996 Dodge Ram
JKEV1986
  • 1996 DODGE RAM
  • V8
  • 4WD
  • 157,000 MILES
WHAT THE TRUCK DOES IS IT DROPPES THE LAST GEAR THEN IT PICKS IT BACK UP BY IT SELF LIKE IF I WAS TURNING THE OD ON AND OFF IT DOES IT BY ITSELF GOING AT A STEADY SPEED AND WITH OUT FORCING OR PRESSING THE GAS PEDAL
Tuesday, April 20th, 2010 AT 7:08 PM
  • 110,176 POSTS
Has the check engine light come on? Is the ATF clean and full?
Wednesday, April 21st, 2010 AT 7:53 AM
JKEV1986
The check engine light it is on and it sais its the speed sensor but I chandged it and erased the code and it came back on for the same code the truck is lifted and has 35 tires they told me thats why the check engine light comes on because of the tires the transmission got an oil changed about 3 weeks ago because I tought that was the problem but it didnt change anything it still does the same thing. Thanks for replying to my question I hope you can give me an idea of what it is
Wednesday, April 21st, 2010 AT 10:33 AM
  • 110,176 POSTS
The only other thing I can think of is if there is a problem with the converter or the front pump which allows the pressure to drop to a point that the trans disengages.
Wednesday, April 21st, 2010 AT 1:40 PM
