1995 Dodge Ram truck wont go into 5th gear or reverse
283,000 MILES • V8 • 4WD • MANUAL
HDPEACE
i can shift into every gear with no problem but i can't shift into 5th or go into reverse.
Oct 5, 2010 at 11:36 AM
  • 110,246 POSTS
With the engine off, can you shift into R and 5th?
Oct 6, 2010 at 5:06 AM
HDPEACE
with the engine off i can shift into 5th but not reverse.but when i turn the engine on it wont move in 5th.
thanks for your time
Oct 6, 2010 at 2:33 PM
  • 110,246 POSTS
I hate to say it, but it sounds like there is internal damage to the transmission. My guess is a fork has broken or something has come loose. If you can't shift it with the engine off, it must be internal unless there is a problem with the linkage.
Oct 7, 2010 at 6:18 AM
