1995 Dodge Ram temperature senor
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
RGVEN
due to cold weather temperature engine will crank but fuel seam's not to reach the carb. i think it is the temperature senor but i cannot locate the senor .i found a one wire senor next to heat hose along side radiator hose on engine block but cannot found any other one.
Oct 5, 2009 at 11:14 AM
  • 110,251 POSTS
Will the engine start with starting fluid? Also, have you checked fuel pump pressure?
Oct 6, 2009 at 3:08 AM
