Engine has a noise that occurs at valve rocker speed
14,500 MILES • V8 • 4WD • MANUAL
GRIS
  • 13 POSTS
It has been doing it for the last 4,000 miles. It sounds a lot like a tappet. At cold idle, it is quite loud. It gets quieter when the engine is completely warm. It gets louder as I first speed the engine up to take off. Then it gets quieter. If you just rev the engine up to about 1,500, it gets louder just at first, and then gets quieter. After driving for a short while, when the engine is hot, I cannot hear it at idle. As soon as I push the accelerator down a little to take off, it get louder. As the engine speeds up, it seems less loud, but I think that is because the pecks come closer together, and there is less time for whatever is making the noise to do so. It is very hard to hear at 2000 rpm, but that may be because of the other engine noise. I have had two other mechanics listen to it, but they have no answer.
I have replaced all the cam followers, checked all the push-rods for straightness, inspected all the rocker arms and the blocks that hold them down for clearance and wear. I bought two new blocks and the yoke that keeps them in alignment, as I thought I had discovered a worn place. I looked at the cam position sensor and replaced it about .015 further out to see if it might be the timing chain with a loose spot. None of these things has made a difference. well, the new tappets may be slightly different, but the noise has not gone away. I have not checked the timing chain and gears, but, since the noise is at rocker speed, I thought this was unlikely.
1995 Dodge W2500, V10, 5sp, a/c, 145,000 miles, cold idle oil pressure 60#, warm idle, 40#, warm 3000 70#.
Mar 18, 2009 at 12:23 PM
JAMES W.
  • 2,394 POSTS
From the way you describe the noise and the rpms at which it comes and goes, it sounds to me like you've spun a rod bearing. What is your oil pressure like at warm idle?
Mar 18, 2009 at 7:06 PM
GRIS
  • 13 POSTS
Did you read the whole questiion? The warm oil pressure is listed at the end of it. It is #40.
Mar 18, 2009 at 11:35 PM
JAMES W.
  • 2,394 POSTS
Sorry, I missed that part. You mentioned you changed all the cam followers, did you mean the hydraulic lifters? The only thing else I can think of that would cause the noise you describe is timing chain hitting the cover. Grab the crank pulley and move it back and forth to see how much slack you have. You'll be able to feel when the crank trys to turn the cam. Let me know.
Mar 19, 2009 at 7:40 AM
GRIS
  • 13 POSTS
[quote:925ff2851a="James R. Weizel"]Sorry, I missed that part. You mentioned you changed all the cam followers, did you mean the hydraulic lifters? The only thing else I can think of that would cause the noise you describe is timing chain hitting the cover. Grab the crank pulley and move it back and forth to see how much slack you have. You'll be able to feel when the crank trys to turn the cam. Let me know.[/quote:925ff2851a]
OK. I haven't actually done that. I would have thought that a timing chain slap would not be so regular. This noise is dead even, with no oscillation. I will check your suggestion.
Yes. Lifters, followers. This is the first engine I have owned with roller lifters.
PS, I know about the tree/forest thing.
Mar 19, 2009 at 11:13 AM
JAMES W.
  • 2,394 POSTS
Even though you'd think the tension on a timing chain would be the same all the time, they will slap when you quickly crack the throttle.
Mar 19, 2009 at 11:42 AM
GRIS
  • 13 POSTS
I put a breaker bar and a socket on the front pulley and wiggled it. Then I turned it some and wiggled it again a number of times. There are some positions where I am sure there is no noise and some where there may be a slight noise. It is hard to duplicate the force that the parts are under when the engine is running. When the engine is running, you can hear the noise if you lie underneath the truck.
I guess my concern is, why is the noise so regular? It also does not sound like a rub, but more a tap. I would have thought chain slap would be irregular? It does get slightly quieter when the engine is fully warmed, but cast iron does not expand much, nor does the steel in the chain.
It does make more noise under slight acceleration, and less under deceleration. I suppose it could be the chain loosening in one case and tightening in the other. I think it is quieter at about 2000 rpm. It also gets slightly quieter after you accelerate and then go to neutral throttle.
Mar 21, 2009 at 8:36 AM
JAMES W.
  • 2,394 POSTS
When you turn the crankshaft back and forth, your not trying to replicate the "tapping" sound, you're trying to determine how many degrees of slack you have when the chain tightens against the cam. 1 to 2 degrees for an engine with your mileage would be normal. 10 degrees or more would be a lot of wear.
Mar 21, 2009 at 10:25 AM
GRIS
  • 13 POSTS
How would I know how many degrees the crank moves before moving the cam without removing the timing chain cover or the intake manifold? There is way too much internal friction in a V10 to just feel it.
Mar 21, 2009 at 11:34 AM
JAMES W.
  • 2,394 POSTS
Use your timing marks. Turn the crank clockwise 'til you get the mark on the balancer to "0" or TDC, which ever you have. Then, slowly turn the crank "counterclockwise" until you feel the chain start to move the cam.
Mar 21, 2009 at 1:45 PM
GRIS
  • 13 POSTS
Well, I cannot use my timing marks. The V10 has a crank position sensor in the side of the block, behind the motor mount. The front pulley has no marks on it, only balance holes.
I marked it and ran a straight edge from an oil pan bolt to the radiator shroud. Then I moved the pulley back and forth. If I picked a place where I could hear the noise that I mentioned above, I get about 1/4" movement of the mark on the pulley. If I am doing the calculation correctly, that translates into just short of 4 degrees.
If that means the chain is too worn, I can change it. I have changed Shell Rotella 15w40 and the filter every 3000 miles. You have to wonder what you would have to do to get the chain to last the life of the engine.
Mar 22, 2009 at 2:08 AM
JAMES W.
  • 2,394 POSTS
Ya' done good. If that's all the slack you have, the chain's good for another 100K miles. The only other thing I can think of without actually hearing the noise is something that's "belt driven. Have you tried removing the belt(s) and running the motor for a little bit and see if the noise is still there?
Mar 22, 2009 at 4:09 PM
GRIS
  • 13 POSTS
Removing the serpentine belt makes no difference, whatsoever.
I noticed this noise about 4000 miles ago, but it did not come on slowly. It came on fast. It is a peck or a tap, quite metallic, with no scraping associated with it. It is as if a valve were not closing and the pushrod was coming up and hitting it.
Some listeners have said to just let it go, but I don't like that idea much.
Mar 23, 2009 at 2:26 AM
JAMES W.
  • 2,394 POSTS
When this "tapping" noise exists, does the engine miss or seem to drop a cylinder?
Mar 23, 2009 at 5:17 AM
GRIS
  • 13 POSTS
No. It runs evenly, and the fuel mileage is the same as it has always been.
Mar 23, 2009 at 8:53 AM
JAMES W.
  • 2,394 POSTS
Gris, there was a TSB issued for '94-'95 Dodge trucks where they made a tapping/fluttering noise during light acceleration/deceleration. It has something to do with the air intake system. You may want to give your local dealer a call to get more info. Let me know what you find.
Mar 23, 2009 at 2:02 PM
GRIS
  • 13 POSTS
Don't ya love it? My local Dodge dealer just folded. I will check to see if I can get help from the one that is 50 miles away.
Mar 23, 2009 at 11:58 PM
JAMES W.
  • 2,394 POSTS
OK, I'll try to send you what I have on the TSB.
Mar 24, 2009 at 8:58 AM
GRIS
  • 13 POSTS
Thanks. I can find no TSB on line that talks about this sort of noise. I did not get a chance to call the Dodge dealer today.
Mar 24, 2009 at 11:46 AM
JAMES W.
  • 2,394 POSTS
Just happened to be passing your site and wondered what was going on....
Mar 29, 2009 at 11:21 AM
GRIS
  • 13 POSTS
I have not been able to find any TSB's that address my problem.
Mar 29, 2009 at 11:52 PM
GRIS
  • 13 POSTS
First, I am wondering if you have found any further info in TSB's?
Second, I bought a stethescope. Listening in a number of different places on the engine, the heads have no abnormal noises. The timing chain area sounds nice and smooth, as do other places on the block. It is hard to get to the injectors, but thethree that are easy make a noise at the correct speed, which is not surprising, as they fire once per two revolutions. If I listen in a couple of places on the manifold, I seem to hear the noise.
My question is, is there a proceedure for testing the injectors? Could one of them be making an unusual amount of noise?
Thanks.
Mar 31, 2009 at 2:13 AM
JAMES W.
  • 2,394 POSTS
Injectors won,t make noise that you can hear with the naked ear. I don't know what else to tell you.
Mar 31, 2009 at 4:49 PM
GRIS
  • 13 POSTS
OK
In that case, is there anything else that will make a noise that is louder at the top of the engine than at the bottom, is louder with the stethescope on the manifold than on the heads, timing chain case, water pump, bottom of the block or any of the various pumps and alternator on the engine, and is really loud on an injector?
I would think that I had made a mistake of some sort with the lifters if the noise was any different after I had put new ones in, but it ain't.
Apr 1, 2009 at 12:19 AM
JAMES W.
  • 2,394 POSTS
You can check the injectors by unplugging them one at a time to see if you can eliminate the noise. I re-read your post, and the only other thing I can think of would be a cracked or broken piston skirt. The only way you'll know is to drop the pan and check each piston from below.
Apr 1, 2009 at 6:41 AM
95V10ONETON
I am having this same exact issue with my 1995 v10 3500 club cab off road. Trucks only got 110,000 and this is driving me insane. What did you ever discover it was? Really hoping for an answer this made my night been searching for months.
Apr 6, 2020 at 1:02 PM
Okay. Have you made any repairs on this issue? Most likely this is a lifter noise but please see the attachment as valve guides or spring issues can cause very similar noises.
Can you get a recording of the noise and I can take a listen to it and we can go from there? Plus let me know what you have done so far and we can figure this out. Thanks
Apr 7, 2020 at 12:07 AM
