1995 Dodge Ram Starting problems
145,000 MILES • V8 • 2WD • AUTOMATIC
MARABY265
My battery is only a couple of years old and I'm pretty sure it's not the starter. When I try to start the engine nothing happens. I have to keep trying and finally it does start and then runs fine. Do I just need to replace my fuel filter?
Jan 4, 2009 at 3:41 AM
  • 110,248 POSTS
Hi:
when you have the problem, check for power to the starter. Have a helper turn the key to the start position and check for power to the small wire on the starter. You should get 12 volts. Let me know what you find.
Jan 4, 2009 at 10:54 AM
