1995 Dodge Ram Shifting Problems
154,000 MILES • V8 • 4WD • AUTOMATIC
CVF1967
My 95 Dodge Ram all of a sudden, is not able to start in Park and will only start in Neutral. Also, at the same time this happened, the transmission will not shift out of low gear until you reach about 40 MPH from a dead start. Once it finally shifts out of low gear, it's fine, until you stop again and then stays stuck in low gear until reaching 40 mph. Please advise as to your opinon of both these problems. Thanks
Mar 29, 2009 at 12:47 AM
BILLYMAC
  • 2,204 POSTS
as far as no start in park....neutral safety switch..running too long in low adjust linkage be sure trans level is full and clean.this is all you can do besides serviceing trans.
Mar 29, 2009 at 2:09 AM
