1995 Dodge Ram Shifting is irregular
120,000 MILES • V8 • 2WD • AUTOMATIC
JJRYNO
This truck does not shift at the right times, usually in higher gears. It displays code 11 and code 37 or 39. (to do with a transmission solenoid). Is this solenoid easy to replace or is it inside the transmission?
May 7, 2009 at 9:10 AM
2CARPRO JACK
  • 11,533 POSTS
11- no crank signal during cranking. 37- has 3 different possibilities, Torque convertor clutch solenoid or trans temp high/trans temp low 39-I dont show on my code list. code 11 could be a crank sensor or cam sensor but the 37 may be the TCC solenoid which is inside the trans or overdrive solenoid which is external (see pic)
https://images.2carpros.com/forum/automotive_pictures/1639_1_3.jpg
May 9, 2009 at 5:17 AM
