1995 Dodge Ram shifting
239,000 MILES • 6 CYL • 4WD • AUTOMATIC
BALLJA
I have a 1995 dodge ram that has 239K miles on it and I have had the transmission redone 4 years ago.
It was running perfectly but the other day I noticed it loosing power as I was climbing a hill and it wasnt shifting automatically it would stay in the 3 rpm and not shift down. I put more transmission fluid in and anti freeze and oil but this did not solve the issue. it says its code 55 but I am not sure what that means.
Any suggestions?
Thank you
Janet Ball
Oct 28, 2010 at 6:47 AM
  • 110,248 POSTS
Hi:
A code 55 means the computer has completed its check. If there are no other codes, nothing is stored.
As far as the problem, how low was the trans fluid? Is it clean or does it appear dark and have a burnt smell?
Oct 29, 2010 at 1:54 AM
