1995 Dodge Ram Seat Belts
113,000 MILES • V8 • 2WD • AUTOMATIC
SHURLBERT
How can I test our seat belts to make sure they work? The passenger side (3 point) belt snugs up across my hips and stays tight. The driver's side gives with movement. Should it tighten up?
Does it have anything to do with the fact that the driver's side has an airbag and the passenger side does not?
Sep 11, 2009 at 10:11 AM
  • 110,244 POSTS
The seat belt shouldn't lock up until there is impact. If the passanger side is tight and won't release, you should replace it.
Sep 12, 2009 at 11:36 AM
