1995 Dodge Ram removing lower transmission cooling line fro
230,000 MILES • V8 • 2WD • AUTOMATIC
HELIKEN
not sure how the line disconnects from the radiator
Nov 22, 2009 at 6:43 AM
JSWAIN
  • 24 POSTS
Is a quick connect fitting. Requires special tool. Can be bought at autozone, etc. The tool is easy to use, just clamps over metal line, then you push the flange of the tool up into the connector and slip the connection apart.
Nov 22, 2009 at 12:48 PM
