1995 Dodge Ram no charging
15,600 MILES • V8 • 2WD • AUTOMATIC
COMMANDO
My 95 ram 1500 will not charge. i replaced the alternator with a rebuilt unit and the same condition exists. I read the voltage reg is biult in the computer. Is this the case? Can i replace the computer with one from a salvage yard?
Oct 1, 2010 at 7:43 AM
  • 75,988 POSTS
Hi commando@bayland.net, Welcome to 2carpros and TY for the donation
If all the exterior wiring in the charging system checked out-could be coming from the computer field generation circuit of the alternator-You can try another computer or a new one make sure you have it flashed
Oct 1, 2010 at 8:44 AM
COMMANDO
would i have to flash a used one also?
Oct 2, 2010 at 6:31 AM
  • 75,988 POSTS
Try the used one if it will work without a problem, if you encounter problem have it flashed
Oct 2, 2010 at 10:19 AM
