1995 Dodge Ram maint req light
93,000 MILES • V12 • 4WD • MANUAL
BJPFORBES
How do I reset the maiintainence req light myself on my 1995 dodge V10 pu
Sep 28, 2010 at 1:20 AM
WRENCHTECH
  • 20,760 POSTS
On certain models, this Emission Maintenance Reminder System is incorporated into the engine controller. The controller stores vehicle mileage into its memory every 8 miles, then at 60,000, 82,500 or 120,000 miles it will illuminate the EMR lamp. When the indicated mileage is reached or the EMR lamp is on at all times, the following parts must be replaced and the EMR lamp reset.
1. At 60,00 miles, proceed as follows:
1. Replace EGR valve.
2. Clean EGR passage.
3. Replace PCV valve.
2. At 82,500 miles, proceed as follows:
1. Replace oxygen sensor.
3. At 120,000 miles, proceed as follows:
4. After necessary emission maintenance has been performed, connect Diagnosis Read-Out Box II (DRB II) to the on-board diagnosis connector.
5. Follow instructions indicated by DRB II tool.
Sep 28, 2010 at 1:35 AM
