1995 Dodge Ram 1995 Ram 1500 5.9 Oil Pressure Light
1995 DODGE RAM
185,000 MILES • V8 • 2WD • AUTOMATIC
WORMSSUNBIRD
  • 6 POSTS
After the engine reaches operating temperature, my "Idiot" oil light on the dash starts to flicker, but only when i come to a stop or idling. It does not stay lit it just flickers. Then when i give it gas to take off the light quits flickering. The oil gauge shows a pressure reading however it seems low, and while watching the gauge one time the needle did bury to zero until i revved the engine then pressure was back for a short time. I changed the oil pressure switch already and that didn't fix it. HELP.
Jan 24, 2009 at 1:14 PM
If you check the oil pressure with a mechanical gauge and its normal and you replace the pressure switch-then your oil pressure gauge is out of calibration. Now if its abnormal could be the oil pump sticking/clogged pick-up screen/etc. Do you hear knocking noises when its happening?
Jan 24, 2009 at 5:09 PM
WORMSSUNBIRD
  • 6 POSTS
No, when the light is flickering no noises are heard from the engine i forgot to mention that in my original question. If it is the oil gauge thats out of calibration how do i fix that?
Jan 24, 2009 at 10:40 PM
Double check the wiring if okay replace the oil pressure gauge.
Jan 25, 2009 at 8:27 AM
WORMSSUNBIRD
  • 6 POSTS
thanks for your help
Jan 27, 2009 at 8:18 AM
