1995 Dodge Ram Low oil pressure
238,000 MILES • V8 • 2WD • MANUAL
BELNCHRIS
The oil pressure gauge is fluctuating non-stop at idle it sits between 35-40psi. When I put it in gear,any gear it is between 0-20psi. I have changed the oil and there was no change. Coud it be the gauge,oil pump, sludge? I don't know I just know I need that truck. Thanks a million.
Jul 25, 2010 at 1:49 AM
  • 75,988 POSTS
Do you hear any type of engine knocking noises do below
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch. If abnormal could mean oil pump failing
Jul 25, 2010 at 8:12 AM
