1995 Dodge Ram Engine Runs terrible cold, fine warm.
1995 DODGE RAM
BLONG4LIFE
Engine Performance problem
1995 Dodge Ram V8 Four Wheel Drive Automatic 5.9 miles
95 Dodge Ram 2500 5.9L Gas 4x4.
Problem is, when my motor is cold, it runs bad, backfiring (sounds like a popcorn machine). Once the computer hits 180 or so, the problem just seems to go away.
Problem is, when you hit the gas while it's doing this, it just bogs out...sometimes stalling. Also causing erratic idle issues.
Truck has new timing chain, alternator, all 16 valves replaced, and a new crank sensor.
Thanks for the help.
Feb 22, 2010 at 4:09 PM
SCOTTY DEE
  • CAR REPAIR CONTRIBUTOR
  • 592 POSTS
Are there any trouble codes present?
Feb 22, 2010 at 6:37 PM
BLONG4LIFE
o2 sensor too lean. fuel pressure is good, too (45 psi, spec is 49, within 5 PSI)
plenium was bad, had a clogged cat, for now I did gut the cat, but the sensor is before the o2 sensor, don't know if this would affect the reading, there is no post-cat o2 sensor.
trans over temp too -- but that shouldn't apply to this.
Feb 22, 2010 at 8:03 PM
SCOTTY DEE
  • 592 POSTS
Can you tell me what the present codes are? I need the code numbers.
Mar 1, 2010 at 2:54 PM
BLONG4LIFE
Currently no codes are present (self-reset), IIRC it was code 43.
Mar 2, 2010 at 9:02 PM
EDDIE7644
  • 14 POSTS
Try taking the O2 sensor out of the exhaust, (the one before the cat) and start it and see how it runs. THis will tell you if your cat is bad it should run good with it out.
Mar 5, 2010 at 3:01 PM
BLONG4LIFE
Cat is already know to be bad and gutted.
Took it to someone I know with a DRB3, said Sync between camshaft and crankshaft sensors was off. New crank sensor, replaced cam sensor last night. Ran better but still iffy this morning, I ran some sea foam through the vaccumm lines and changed the oil, and I'll see how to does tommorrow morning.
Mar 5, 2010 at 3:37 PM
2 LINSEY
  • 287 POSTS
Hi, Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 9, 2010 at 4:48 PM
BLONG4LIFE
Problem still persists, ordering a computer for it.
Mar 9, 2010 at 8:41 PM
2 LINSEY
  • 287 POSTS
Please let us know how it all turns out.Thanks again for using 2carpros.com.
Mar 12, 2010 at 4:23 PM
