1995 Dodge Ram engine dies when shifted into gear
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
MDUNCAN525
Driving home my engine died. No big noises. I restarted it and as soon as I put it in gear it dies. Immediately. No laboring or trying to run, just dies. It idles/revs perfectly in P or N then dies instantly if you put it in gear. (If you just shift thru R to N it will stay on long enough to get into N) There is some fluid leaking from underneath the transmission. Hoping this is not a full trans rebuild.
Apr 23, 2010 at 5:29 PM
  • 110,248 POSTS
IS the fluid red?
Apr 24, 2010 at 3:40 PM
MDUNCAN525
couldn't tell too much at night, but it didn't look burnt. The van is at a yard right now, but being towed back to me in a day or two, so I can check then.
Apr 24, 2010 at 3:44 PM
  • 110,248 POSTS
When you get it, let me know what you find. If it is ATF, let me know an aprox area that it is coming from.
Apr 24, 2010 at 3:52 PM
