Driving home my engine died. No big noises. I restarted it and as soon as I put it in gear it dies. Immediately. No laboring or trying to run, just dies. It idles/revs perfectly in P or N then dies instantly if you put it in gear. (If you just shift thru R to N it will stay on long enough to get into N) There is some fluid leaking from underneath the transmission. Hoping this is not a full trans rebuild.
SPONSORED LINKS
Saturday, April 24th, 2010 AT 12:29 AM
MECHANIC
IS the fluid red?
Saturday, April 24th, 2010 AT 10:40 PM
MDUNCAN525
MEMBER
Couldn't tell too much at night, but it didn't look burnt. The van is at a yard right now, but being towed back to me in a day or two, so I can check then.
SPONSORED LINKS
Saturday, April 24th, 2010 AT 10:44 PM
MECHANIC
When you get it, let me know what you find. If it is ATF, let me know an aprox area that it is coming from.
