1995 Dodge Ram breakes
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
C69CHARGER
the breakes are loocking up on me . i guess this is causing the truck to overheat.
i replaced the breakes and the calipers last week and it still is not fixed the problem.
the rims are so hot you could fry a egg.
Jun 11, 2010 at 8:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
any brake fluid leaking? check around wheel cylinders make sure they are not leaking fluid onto brake surface, that will lock it up quick.
Jun 11, 2010 at 8:58 AM
