1995 Dodge Ram backfires horrible only when cold
PATRICK COX
  • 1995 DODGE RAM
  • V8
  • 125,000 MILES
Need help when is engine cold start 12 or more hours vehicle will run like it`s jumped timehave replaced coolant sensor replaced computer with new parts has extremely long injector pulse width 30ms floods engine gas mixed in oil if you put trans in reverse it will idle somewhat and only in reverse have checked the wiring from coolant sensor air temp sensor map sensor from each sensor to computer no problems found has no open wires all connections appear good on scan tool at cold start if outside air temp is 40 degrees coolant sensor and air temp read 40 degrees if you can keep engine running long enough to reach 185 degrees engine will run good my question is what is responsible to let in injector pulse for this long oh forgot also has new crank sensor and pickup coil and I have indexed the dist. Also this problem showed up out of nowhere any help is appreciated
Monday, January 11th, 2010 AT 7:24 PM
  • 109,740 POSTS
The PCM receives information from the temp sensor to determine the amount of fuel needed. THat has to be where the problem is. It could be a broken wire corroded connection. If all is good, I would turn to the PCM itself.
Thursday, January 14th, 2010 AT 8:28 AM
