abs/engine light, front end shaking
KIMKAY28
I recently bought this truck and the 2nd day i drove it, the abs and brake light came on and has been on ever since. Any suggestions? Also, when I start slowing down and am almost at a complete stop, there is major vibration from the from end (the steering wheel is not aligned also) is it just in need of of front end alignment? I didnt pay that much for it and dont want to stick tons of money into it. Any advice would help:)
Mar 17, 2008 at 10:37 AM
SQM
  • 6,383 POSTS
Typically, vibrations are due to worn or damaged components.
It will be a good idea to do a thorough inspection of the suspension components. Look to excessive play in the lower ball joints. Check the bushings for the control arms. Look for any damaged components.
Here is a helpful guide that goes over the typically issues:
https://www.2carpros.com/articles/popping-noise
The ABS light gets illuminated when the on-board diagnostics detects any fault within the ABS system. It can be a bad wheel speed sensor to a faulty module. Since the ABS light is on, have the codes retrieved. It can help with the diagnostics.
Faulty ABS can also create pulsation on the brake pedal.
Take a look at this video, it shows how to check for those codes:
https://youtu.be/rTtAnsOlZU4
Oct 31, 2021 at 1:40 PM
