1995 Dodge Ram 4-wheel engage on front axle
126,000 MILES • V8 • 4WD • AUTOMATIC
DODGE6200
on pssnger side front axle I have a clutch or assembly with a hydrlic hose from it to frame above and ending with plastic cap. It started to leak noticeably 2 days ago. It is now an infrequent drip. What is it and how do I ap or stop leak/drip.
Jun 14, 2010 at 10:09 AM
98RAMMAN
  • 7 POSTS
The part is your 4 wheel drive actuator. It sounds like the gasket is leaking or the oring/seal. depending where the leak is coming from. to cahnge the fgasket you would have to remove 4 bolts and gear lube will come out.
Jun 16, 2010 at 1:30 PM
