1995 Dodge Ram
AHUNT
Engine Mechanical problem
1995 Dodge Ram 6 cyl Two Wheel Drive Automatic
car starts up but when put into drive it stalls out.throttle position sensor was replaced it was not the problem. please help.thank you
Feb 17, 2009 at 10:49 AM
  • 110,248 POSTS
Check for vacuum leaks. Make sure the intake isn't leaking. Also, is the check engine light on? Have you checked to see if the catylatic converter may be plugged?
Feb 24, 2009 at 1:25 AM
