1995 Dodge Ram
OSCARGR
Engine Mechanical problem
1995 Dodge Ram V8 Two Wheel Drive Automatic
my truck will not start, the starter works fine but the it won´t start, could it be the fule pump or the fule filter. by the way where is the fule filter located?
Jul 14, 2010 at 7:34 AM
JDL
  • 16,098 POSTS
It's on top of the fuel pump module. I didn't check all litre sizes. Have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you con't have one.
Jul 14, 2010 at 8:53 AM
