1995 Dodge Ram
JCHUDSON
Drive Train Axles Bearings problem
1995 Dodge Ram V8 Four Wheel Drive Automatic
4WD will not engage when I shift to 4-high or 4-low back wills spin but nothing from front wheels.
Jan 16, 2009 at 7:15 AM
  • 110,248 POSTS
Hi:
Is this a manual or electric shift 4wd? Have you checked for vacuum leaks? Have you checked the vacuum actuator on the transfer case for proper operation? Have you checked the vacuum lines to the front differential for vacuum?
Jan 20, 2009 at 1:08 PM
