1995 Dodge Ram
130,000 MILES • V8 • 4WD • AUTOMATIC
CSTRAIT
there is little to no heat coming out the vents not even enough to keep the windshield clear while snowing. i have tried reversing the hoses on the core and also flushing water through the core with a hose. the core does not seem to be the problem. the system is topped off with coolant, all the controls work fine and i am running out of ideas. please give me a few. thank you.
Dec 10, 2008 at 9:45 AM
JAMES W.
  • 2,394 POSTS
Have you tried changing thermostats?????
Dec 10, 2008 at 10:30 AM
CSTRAIT
yes i changed the thermostat and flushed the system
Jan 2, 2009 at 2:35 PM
JAMES W.
  • 2,394 POSTS
Are your in/out hoses form the heater core hot? And, are you sure the blend door in the heater box is moving from heat to cool and back?
Jan 4, 2009 at 11:20 PM
CSTRAIT
yes both lines are hot and the the air door moves freely i can hear it switch back and forth
Feb 4, 2009 at 4:02 PM
