1994 Dodge Ram truck stalls when hot
JASON77_5
1994 Dodge Ram V8 Four Wheel Drive Automatic
I can drive the truck until it gets hot then it will stall you haft to let it sit and cool then it will start again.i have replaced the brain the cam sensor the coil the cooling sending unit the fuel pump. I still get the same thing
Apr 16, 2009 at 1:56 PM
  • 75,988 POSTS
Check the idle air control motor, throttle position sensor, EGR and PCV valves. Also might want to check out the crankshaft position sensor.
Apr 17, 2009 at 11:33 AM
