1994 Dodge Ram my truck
85,000 MILES • V8 • 2WD • AUTOMATIC
OPBROWNING
my truck seems to be having a problem at this time. it starts up fine runs fine but then as it warms up and been driving for a little while idels at around 500 rpms and sometimes stalls out while at stop signs or turning. have cleaned out the intake and have replaced the fuel filter and have ran injector cleaner through it, also have cleaned out the idel air control motor, ran computer check and came back with o2 sensor short, not sure yet if egr valves are sticking as of this moment but truck will get up and go after it begans to dye down and i get into the gas where should i start at getting this problem fixed? the egr valves or the o2 sensor? all hoses and vacume line seem fine at this time.
Apr 7, 2009 at 9:27 AM
BMRFIXIT
  • 19,053 POSTS
EGR will make it run rough and unstable
what do you have for codes ?
I would start with what I have if its a bad O2 sensor so let it be
be careful as not all O2 sensor codes mean sensor bad
need a scanner do an idle stall minimum air test
Apr 7, 2009 at 11:10 PM
