1994 Dodge Ram My Dodge pickup has a problem.
158,000 MILES • V8 • 2WD • AUTOMATIC
CARL41467
My 1994 Dodge pickup truck, 3/4 ton, 2wheel drive, with a 5.9 L magnun. It will start and run, but it will also quit running, like some one turned the key off. I can put it in park, turn the ignition to fully off, and wait just alittle bit and it will start and run like nothing is wrong. then it will go 1 to 50 miles down the road, and it will happen again. Have you heard of this, and what should I look for; to find a solution?
Oct 26, 2010 at 2:32 AM
  • 110,244 POSTS
Has the check engine light come on? It sounds like a crank sensor, but I can't be sure without an engine code.
joe
Oct 29, 2010 at 1:48 AM
