1994 Dodge Ram my 1994 dodge ram 350 van wont start.
150,000 MILES • V8 • 2WD • AUTOMATIC
SCDALLAS03
we tried replacing distributer cap,could not find the fuel pump relay
Oct 31, 2009 at 11:26 PM
  • 75,988 POSTS
Do below to determine if the problem is fuel or spark
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Nov 1, 2009 at 4:47 AM
