I had a problem w/ smoke coming from the dash light switch, and then the headlights didn't work. I removed and examined the switch. The terminals had overheated and the harness housing had melted a little.This left the contacts blackened and it had lost electrical contact. I cleaned the terminals up and reconnected switch to harness. Same thing - overheated and something started melting/smoking within 10 seconds. Headlights came on fine. Is this likely a switch problem or should I look elsewhere in the circuit. If it is a short, shouldn't a fuse blow? I looked in the manual, and couldn't even find a fuse designated for the headlights. If it is a switch problem, any suggestions on a web supplier?
Jul 22, 2008 at 12:16 PM
