1994 Dodge Ram fuel system
116,800 MILES • V8 • 4WD • AUTOMATIC
SPYDER254
when ever my truck gets low on gas, around a 1/4 tank it starts hesitating and will not accelarate, will lose power and only go about 20mph, the check engine light will come on and then go off if I put more gas in, also as it loses power it will make popping sounds in the engin compartment and yes I am sure that my fuel gauge is accurate....we are poor please help, will donate when we can
Dec 5, 2007 at 4:45 PM
  • 75,988 POSTS
Hi and welcome to 2carpros
1st we need to know what that check engine light code/s is. You might want to check out autozone parts store and get it read for free.
Meanwhile with a repair manual-you can check the fuel pressure, inspect for exhaust system restriction-ruling out the catalytic converter/mufflers and last the throttle postion sensor closed and wide open throttle voltages.
Is there anything else I can do for you?
Dec 5, 2007 at 5:51 PM
