1994 Dodge Ram engine stalls on my work truck
KMK69
  • 1994 DODGE RAM
  • V8
  • 23,500 MILES
My ram truck will start and idle rough and eventually the engine will drop RPM's and stall out. I have change the cap and rotor and also went through the spark plugs and wiring. That's OK. I have check the fuel pressure and it was 27psi when the key is turn on and 12psi at idle, so I change the fuel pump and still have the same problem. With the engine idling rough and engine stalling out. I also looked at vacuum lines and did not see anything out of place. Now when you press the brake pedal down it will stall the engine quickly. It's maybe a sensor but I not sure where to start.
Tuesday, July 27th, 2010 AT 9:49 AM
  • 109,896 POSTS
The last thing you mentioned, brakes, leads me to believe that you either have a bad brake booster or the hose going to it is bad. Have you vacuum tested the booster to see if it holds vacuum?
Tuesday, July 27th, 2010 AT 9:13 PM
