1994 Dodge Ram Distributor
RMCOFFEE
Engine Mechanical problem
1994 Dodge Ram 6 cyl Two Wheel Drive Automatic
My destributor recently stopped turning so I went and bought a new one. I put it in and it stell isn't turning. The engine turns over just fine but the part that is supposed to turn the destributor will not turn. I replaced the oil pump about a year ago and the shaft looked fine. I am not sure what is supposed to turn it and I need help so I don't just keep buying parts.
Aug 9, 2010 at 10:52 AM
  • 110,248 POSTS
If the rotor isn't moving, the distributor driveshaft is either broken or the gear is bad. Here is an exploded view of the distributor drive shaft.
https://images.2carpros.com/forum/automotive_pictures/249084_5_43.jpg
Let me know if this helps. Joe
Aug 11, 2010 at 3:14 PM
RMCOFFEE
I replaced the oil pump drive shaft and I had it started but it keeps jumping out of time. I think the the cam gear that turns it is missing a tooth. Does that sound right?
Aug 15, 2010 at 10:38 AM
  • 110,248 POSTS
that is possible, but unlikely. Was the distributor shaft in good condition?
Aug 15, 2010 at 3:16 PM
