1994 Dodge Ram Dash cluster
173,100 MILES • V8 • 2WD • AUTOMATIC
DRAGONFIGHTER
Guages do not work. Battery loose charge overnight. Horn will not work. Turn signals will not work right. We have replace computer, had alternator checked out and replaced auto shutdown and clutch fan relays.
I was told it could be the crank sensor but I don't know where it is located.
Nov 29, 2008 at 1:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Crank sensor would not have anything to do with these electrical issues you mentioned. The crank sensor gives the engine computer the rotational location of the crankshaft. That is how the computer knows what piston is coming up on top dead center. It needs this info along with the cam sensor(in the distributor) for injector and spark timing.
Have you checked all fuses and all wiring for faults? Could be a hidden accessory left on draining the battery or faulty voltage regulator.
Nov 29, 2008 at 1:44 PM
