1994 Dodge Ram
DODGELADY
  • 1994 DODGE RAM
1994 Dodge Ram 6 cyl
My van stopped running while at a light. When I press on the gas it stopped & would not start running. It would turn over. Wanting to start but couldn't.
It was on E, but I drove approx. 10 miles put some gas in it then drove about 3 miles after the gas station then it stopped & won't start.
We thought it might be fuel line freeze up, but my husband was able to get gas through the bleeder. Its been over a day & its still not starting.
He changed the plugs because someone had told him that he fouled out the plugs when trying to restart it.
What else could be stopping it from running?
Monday, January 11th, 2010 AT 8:10 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Check for spark at plug if good then check fuel pressure 35-45 psi.
Let me know
Thanks for donate
Tuesday, January 12th, 2010 AT 8:50 AM
DODGELADY
We replaced the fuel pump 2 years ago. Could there be ice within the fuel injectiors?
Tuesday, January 12th, 2010 AT 10:11 AM
MERLIN2021
  • 17,250 POSTS
Pump is in the gas tank, if you run around town with less than 1/4 of a tank, the pump can overheat, then you refuel and the cold gas knocks out the pump, very common problem for vehicles driven all the time with low fuel. Test the fuel pressure! Pump can go bad quickly! 2 years old really means nothing.
Friday, January 29th, 2010 AT 7:47 AM
