1993 Dodge Ram Timing
MGOUGE
Engine Mechanical problem
1993 Dodge Ram V8 Two Wheel Drive Manual
An uneducated mechanic without marking before disassembling the engine has got my timing off. No specs can be found on the vehicle. Working off of number one at tdc at what degree do I set the timing? (magnum engine). Computer is compensating but rpms are slow to decrees when you press the clutch. I'm trying to set timing like a shot in the dark, were should it be?
Aug 18, 2010 at 2:19 PM
  • 110,248 POSTS
Do you need the timing chain info or how many degrees BTDC it needs set to?
Aug 18, 2010 at 5:03 PM
MGOUGE
How many degrees
Aug 18, 2010 at 11:56 PM
  • 110,248 POSTS
According to Mitchell online, the timing is not adjustable. If you have modified it so it is, I would estimate aprox 10 degrees BTDC.
Aug 19, 2010 at 2:08 PM
