1992 Dodge Ram no fuel to the engine
35,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHDWBXR_77
truck ran fine for 60 plus miles, then spurted and died. will run when starting fluid sprayed into carb, but not otherwise...ideas?
Feb 5, 2010 at 10:46 AM
  • 110,248 POSTS
IF it runs with starting fluid, it sounds like the fuel pump is bad. Have you checked fuel pump pressure?
Feb 8, 2010 at 11:39 AM
