1992 Dodge Ram leaky hose at top of block
1992 DODGE RAM
68,000 MILES • V8 • 2WD • AUTOMATIC
NSHAKIN
The truck began overheating and blowing off steam while I was driving. After stopping several times to add water, I loosened the radiator cap to reduce pressure at the other end. It was then I discovered the leak at the top of the block where the hose from the radiator enters it. Can I put silicone around the hole/opening to alleviate the problem. I'm not entirely sure if the leak is the hose or the clamp or both.
Jun 2, 2008 at 8:35 PM
BMRFIXIT
  • 19,053 POSTS
if its the hose remove and replace it
silicone will not work on a hose
Jun 2, 2008 at 11:10 PM
