1991 Dodge Ram Speedometer quit working
100,000 MILES • V8 • 2WD • AUTOMATIC
JERRYNC64
Speedometer quit working, changed speed sensor, still not working.
Sep 21, 2010 at 10:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
should use a speedometer cable as well as a speed sensor mounted on the speedometer, make sure it's connected at both ends and is not kinked up somewhere along the way.
Sep 21, 2010 at 10:37 AM
JERRYNC64
There is no speedo cable connected to it. Removed the whole speedo it is electronic, not digital, it looks like an alarm clock. Could the problem be in this unit? There was also a fuse labeled speed control changed it also. Thanks for your help any other ideas?
Sep 22, 2010 at 10:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if its electic and only has VSS then the speedometer assembly may be bad or wiring to the speedo and/or sensor may be damaged. if wiring is good than replacement of gauge is needed.
Sep 22, 2010 at 1:17 PM
