1991 Dodge Ram Over charging problem
186,523 MILES • 6 CYL • 2WD • MANUAL
TANK1992
5.9L Slant 6 Cummins engine - The light became very bright and then went out. The vehicle will still run but the lights don't work and the battery overcharges. What causes this and where do I need to look?
Dec 4, 2008 at 8:58 AM
  • 110,251 POSTS
Hi:
If the alt is overcharging, you need to replace the voltage regulator. If the light's don't work, there is a good chance you burned them out.
Dec 8, 2008 at 10:08 AM
